10-16-2017, 07:47 PM
#22
Re: building a yurt for the winter...
Also, nobody asked, but overlapping the lath sections and lashing them together top to bottom is ALSO the way to go. Similarly, if I built another trad yurt, I ABSOLUTELY would lash the door frame to the lath wall. That is WAY easier then trying to align the lath holes at the door and slide them over bolts set in the door frame. I have split more then one laths trying to get those holes over the screws. MAJOR PITA undoing the lath and redoing due to splits. Plus with the lath wall (khana) lashed to the frame you can adjust the yurt diameter somewhat by making the lath crosses diamonds, and still use the same yurt ring. Mongolians have this stuff all figured out. Lash. Don't bolt.
No opinion about rivets, I have never riveted anything, ever.
