12-02-2021, 11:14 AM
#11
Re: Looking for pony wall plans and examples
Yeah and a truss is a rafter.
As for a framed pony wall under the yurt wall, beats me if it would be OK from a structural standpoint. That building concept is so odd I doubt there is any engineering on the design. Good luck getting $$$ an engineering stamp on that.
If you set a standard Americanized yurt up two feet on top of a pony wall, the windows and entry doors in the yurt will be well above standard height. So, you either order the yurt with the offset factored in, -that's considered a special and will cost you accordingly- or leave the windows and doors out, and have a carpenter frame the openings at standard height. Good luck with that.
In my opinion, if you need extra room for storage, build a platform and use the space under the deck for storage. That will free up space in the yurt. Or get a smaller second yurt.
Better yet in my opinion is to build a conventional shed that can take abuse of use that a yurt can't. I sure wouldn't compromise the traditional design of any yurt, let alone a 30' that cost $$$$.
