11-10-2013, 11:14 AM
#10
Re: Wind and yurt!
With no pics I'm gonna guess a simple solution to ring rotation. How about attaching t shaped 'Simpson Strong Tie' construction connectors to the rafter/ ring joints? (cheap and available at all Lowe's, Depot, lumberyards) They can be bent in a vise to fit your yurt geometry, and screwed into place. The connectors have holes punched in them for nails. But use drywall screws. Be sure you drill pilot holes or the wood will split or screws shear off.
Regarding roof flapping, I've had that on my 16' yurt. To cut down on the amount of flap, I took a 60' length of old 11mm climbing rope and knotted it into a large loop. Then I formed five small anchor loops equidistant around the perimeter of the big loop. I centered that big loop up on the roof cover, and anchored off the five loops with short ropes to my ground anchors. I sized it such that the loop is about halfway from ring to khana. That really cut down on the flapping.
I've seen pics of Mongolian yurts where they simply flip a few ropes over the cover and anchor those to the ground. That cuts down on flapping and also anchors the entire yurt.
