07-17-2023, 02:24 PM
#10
Re: Split heating ac units
Originally Posted by Bob Rowlands
Beats me what a mini split is. And I don't know zip about air conditioning.
Really it is just an AC that works both ways. So like when your window AC is working and you feel the air blowing out the other side, it is WAY hotter than the actual air inside because it is basically working as a heat pump, pumping the heat from your room to the outside.
A mini-split does that but can also be essentially reversed (as I understand it). So instead, it will pull heat from outside (as low as -20+ degrees), compress it and pump it INTO your house in the winter. It will find heat even if it is just a little but compress it into a lot.
They are super efficient, using about 1/3 the power of baseboard electric heat. They are so efficient in fact, many utility companies will give you a rebate if you buy qualified equipment. Here in NY, that can knock your price sometimes in half. They are ductless, so they are great for retrofits.
Unfortunately for me, mine didn't qualify and since we are on municipal power there weren't a lot of options.
