Vapor Barrier On Deck
Old 05-14-2015, 04:00 PM   #1
Default Vapor barrier on deck
So we are close to the point of the platform building that we need to figure out the
and vapor barrier thing. We are pretty sure we are going to go with a mix of roll
and rigid foam to get up to R30 on the floor. The hubby has asked me to look into where the vapor barrier should go or if we should not use a vapor barrier. We are up in central NH, so a pretty cold and wet climate up here to begin with. Mainly looking for suggestions on if we should use something like plastic sheeting or Tyvek and if so should it go up under the T&G flooring or down on the bottom of the platform on top of the OSB?
Old 05-19-2015, 02:35 PM   #2
Default Re: Vapor barrier on deck
So I've been trying to learn more about this same subject. As I've been researching this (I'm no expert by any means), I'm finding that we have to think like stick builders, because that's what most of the info out there is written for in the building sciences.
So first you should consider the structure you're putting the yurt on... is it slab or whatever? You (like me) are thinking a wooden platform. So what is the equivalent in typical stick building? It would seem to me like it's almost a crawlspace.
Here are some links to discussions about issues with crawlspaces and what seems to be the best approaches to insulating them.
BSI-009: New Light In Crawlspaces - Building Science Information
and
3 Problems with Fiberglass Batt Insulation in Floors
and
Building Science 101
The approach that I've seen recommended the most is the encapsulated crawlspace (Crawl Space Encapsulation)... where the vapor barrier is on the walls and ground. But I suspect most of us won't be enclosing the platform of our yurts, so this isn't really valid. Instead, I'll be considering figure 7 at BSI-009: New Light In Crawlspaces - Building Science Information for now because I'll be building in MN and will also use radiant floor heat. This way we'll have insulation in the floor too.
But as the last link says... you need to consider your local climate and the system as a whole. Will you be cooling the interior of the yurt or
it? That's going to matter.
I just found The best way to insulate a floor - GreenBuildingAdvisor.com too.
I'm sure there are others on the forum with more experience, but this is what I've found.
tdsalad is offline   Reply With Quote
Old 05-19-2015, 08:40 PM   #3
I'm a carpenter by trade. Slightly off topic, but all crawlspaces need to be vented by building code. Even if you don't have a permit and an inspector signing off on the project, I know for a fact from experience that all enclosed house foundations need venting to exhaust
. I've worked on some really nasty crawl spaces redoing framing and insulation because of meager 'old school' thinking on venting. Nasty rot termites and ....and I won't give more details. Whatever you end up doing, make sure fresh air can EASILY get through the entire structure, or decay WILL set in. It's that simple.
Moisture
trapped in building materials is a key component in structural degradation.
Old 05-29-2015, 12:05 PM   #4
The standard way in Sweden is, from the inside -> out
1) T&G flooring
2) Plastic vapour barrier (the stuff I use is guaranteed for 50 years). 600mm overlap between rolls. This keeps the moisture inside the yurt from migrating down into the insulation. This is rolled on top of the floor joists.
3) Insulation (between the 600mm centre - centre joists). I use Earthwool.
4) Moisture permeable membrane (Tyvek will do just fine). This allows any moisture that might be taken up by the insulation to dry out.
5) OSB board (or some other board that is not sealed)
hierony likes this.
Old 05-20-2023, 10:41 AM   #5
I'm a carpenter by trade. Slightly off topic, but all crawlspaces need to be vented by building code. Even if you don't have a permit and an inspector signing off on the project, I know for a fact from experience that all enclosed house foundations need venting to exhaust moisture. I've worked on some really nasty crawl spaces redoing framing and insulation because of meager 'old school' thinking on venting. Nasty rot termites and ....and I won't give more details. Whatever you end up doing, make sure fresh air can EASILY get through the entire structure, or decay WILL set in. It's that simple. Moisture trapped in building materials is a key component in structural degradation.
Hi Bob,
This too is slightly off topic, but I’ve seen some of your other post regarding the “bathtub floor” with tarp directly on the ground and wanted your thoughts. Would you suggest adding a layer of house wrap on the ground either under or above the tarp? If not, do you think there is any additional (and inexpensive) layering that can be added in addition to the tarp? Or is it not necessary?
Thank you!
ACW93 is offline   Reply With Quote
Old 05-20-2023, 12:02 PM   #6
Sure, two layers is better than one. Make sure they both fold up on the OUTSIDE of the wall UNDER the cover. And extend high enough up the wall that the low tension band snugs the cover and tub floor to the yurt wall. Just like backpacking tents with the optional footprint, a second tarp will extend the life of the floor. I had a mountaineering tent decades ago I never installed a footprint under. The tent floor rotted out from contact with the ground.
Old 05-20-2023, 02:13 PM   #7
Thanks bob. Yea a platform is in our future, but can’t do it right now, so this is our best option. Hoping the house wrap helps resist moisture improves breathability .
Old 05-20-2023, 02:45 PM   #8
I had my 16'er on a platform.
Rome wasn't built in a day. Enjoy life.
Old 05-21-2023, 05:12 PM   #9
Hey Bob,
Sorry one more question. We have a door at 12oclock w/ windows on each side and a door at 6oclock. In regards to those parts, how could we handle the the tarp that’s overlapping in those areas?
Old 05-22-2023, 09:45 AM   #10
I've built three yurts from scratch, but never installed a bathtub floor. So.. no experience. Since I usually just roll with 'easy' I'd probably just dream something up on the spot. Maybe cut the tarp to fit at those areas and staple it to the door jamb? If that doesn't work try something else. You'll figure it out. Enjoy your new home.
