Originally Posted by Is-ith
Ok so you guys have convinced me. My wife and I are now looking at doing a 16' yurt. I was doing some research and found this video on a supposedly 23' yurt but the poles for the roof look pretty flimsy/small are you guys able to offer some insight on this and why theirs works so well with what seems to be real basic materials... Here is the link.
See about getting time in a shop - I built my first yurt in a local hackerspace with tools. A drill press lets you drill a stack of lattice-slats simultaneously & precisely so the holes line up.
You can use nuts & bolts for the lattice -- I did. But they fall out, even the ones with lock-nuts. My roommate's yurt has the lattice tied together with paracord, kinda like
this. I helped someone replace her yurt's bolts with aluminum rivets (ones with a stop, so they don't squeeze the lattice). While rivets make replacing broken slats harder, I think they're a good balance of sturdy, light-weight, and quick to install (with pneumatic rivet gun) -- they're my plan for yurt 2.0.
For the roof ring:
- You could steam-bend a roof-ring like they did in the video you linked.
- My roommate's yurt is from , out of Oregon - they do great work, and will sell you a roof-ring for under $400.
- I built mine out of plywood and 1x4 scraps - but it's heavy and ugly, I heard horror stories of rings delaminating in the rain and seriously over-built mine.
- My next yurt may have one made of clear PVC bent with heat-gun, filled with UV LEDs, and coated with fluorescent paint so it's also a chandelier. I'm trying to figure out how to build in fans too.
The roof-angle will be dependent on what you need your yurt to do. If you want to leave it set up in the snow, use a really high (>30) angle and really sturdy rafters (I used 1x4s). A lower roof-angle means shorter, easier-to-transport rafters. If you're doing snow-loads, do a lot of research though - that's a lot of weight.
My yurt has rafters that sit on a steel cable, and the steel cable sits on top the lattice. I think that design supports a larger roof-load, as the steel cable takes all the lateral force from your snow-load... also, the steel cable is sized so I know when I've expanded my lattice to the correct size.
My roommate's yurt has a band sewn into the roof-tarp, which he can tighten after the roof is on, so it synches around the rafters for a nice waterproof/dust-resistant seal.
His yurt has the lattice bolt onto a door-frame, which is a good way to be sure it's sized right... but the tolerances are tight so it's always a pain to attach them. Another friend's door-frame has a slot running its full height, so the lattice just slips in and is held in place by the downward force of the roof - no bolts to thread! My yurt door has bungie-cords that wrap around the lattice, that's a dumb way to do it, they stretch out and the lattice gets in the doorway.
Wool
will definitely feel "homier" than bubble-wrap. Just don't let it get wet, or it'll put on hundreds of pounds in a hurry... or muddy. Sounds like you're making this a home that'll move maybe 1/year though - so that might work well for you. Mine's a camping yurt, and the bubble wrap is light-weight and can be flipped to keep me warm or cool.
I built a 19' yurt a few years ago, and awesome as it is to have a yurt, it was my first and is pretty jankey. I want to replace every part of it now because I'd build it all differently. I want to upgrade to a 25' yurt, so I plan to make a ~1/12 scale model to test all the changes this winter. You might consider a scale model too, as it's a good way to check your math and implementation details.
