Dome Shade Solution
Old 05-28-2015, 04:16 PM   #11
Default Re: Dome shade solution
We use an extra piece of the foil
and push it up against the inside of the
. It forms to it nicely and makes a HUGE difference in heat near the
. We leave ours up all summer, but it's literally just pushed in their and takes two seconds to remove and replace.
akcentplanet is offline   Reply With Quote
Old 05-28-2015, 04:28 PM   #12
Here is a pic of our solution. We got the shade screen on Amazon (Something like this: http://www.amazon.com/dp/B00LBUO22K/...rldwidecreatio), then just cut it larger than our screen insert and placed the screen insert up there.
We used 60 or 70% block to give a good amount of shade. This also allows us to open the dome whenever needed.
Old 05-29-2015, 10:32 AM   #13
Off yurts. I make my own wood arrows. With regards to cap, crest, and finish materials, (paints) I've learned to make a test arrow due to failure of the finish not bonding to the cap and crest. I once built two dozen that the finish didn't stick. I even set them in direct sun for several days and that didn't make a difference. It peeled right off with a thumbnail. That learned me fast because it takes ALOT of work to scratch build arrows..
Old 05-30-2015, 01:19 PM   #14
Hmmm....this post was supposed to be directed to Knecht on his Czech yurt build thread?
Old 08-20-2022, 09:45 AM   #15
We've got a 24' yurt from
and had been suffering from the immense heat created by sun through the dome during the summer months here. To make things trickier, our yurt has a ceiling fan, so a lot of the solutions I've seen elsewhere wouldn't fit our dome.
What finally worked? A collapsible photography reflector. It's made of a highly reflective silver fabric on one side and a white fabric on the other. The outside is a band of spring steel that provides outward tension. It's super lightweight, cost $40, and is available on Amazon: https://amzn.to/3RpYDIT
I kinda nestled it into place and its own tension holds itself securely in the crown. It doesn't even interfere with opening and closing the dome, but it does a tremendous job of reflecting direct sunlight back out of the yurt.
Hope this approach is helpful to others!
Sheimend is offline   Reply With Quote
Old 11-11-2022, 10:41 AM   #16
Sheimend, I created an account here just to say this is brilliant, and exactly what I have been looking for. Spent the last 9 years avoiding the yurt in July and August. I almost wish it was summer again so I could try this now. Thanks!!!
FirstThirtyMinutes is offline   Reply With Quote
