Uplighting Or Downlighting?
Old 02-02-2017, 10:28 AM   #1
MT Rod's Avatar
Default Re: uplighting or downlighting?
I think it is really a question of what you like.
Light bounced off the white ceiling will give you a broader, smoother light, but you will lose a lot of the "power" of your light this way, so you will need more light than if you use a direct downlight.
I'm not sure I remember the formula correctly, but light disburses at something like intensity = one over the distance squared. It counts the distance from the source, so it includes the distance to the cover, plus the distance back to your table top for example.
If your light offers 1000 lumens at the source, 3 meters away is it significantly lessened. (1/9).
But I still like the quality of light from a bounced light.
Rod
rodyurtlocker.com
Home Page.
Jafo and friendlytoanimals like this.
Old 02-02-2017, 11:33 AM   #2
I like to have one or two lights shining up onto the ceiling, which provides ambiance and highlights the beautiful roof structure yurts offer, and dimmable lights mounted high that shine downward. If they are on seperate switches this approach makes it easy to set low "mood lighting" or quickly brighten things up for activities or reading.
Old 02-02-2017, 12:32 PM   #3
Thanks for all the feedback, it's definitely appreciated. Sounds like I should aim for a mixture of both. Jafo, I saw your led ring in another thread and it's really pretty - can you read in there though?
friendlytoanimals is offline   Reply With Quote
