10-25-2017, 12:11 PM
#5
Re: Tankless water heater recommendations
Since my water supply is a well, I have a 220v pump (powered by a generator) feeding a pressure tank, so I don't need the 12v pump. I will keep the pump in mind if I get set up for rainwater recovery. As long as the water heater can achieve at least a 60 degree temperature rise at about 1 gpm water flow, it should be fine for my purposes.
PS: I have seen two general types of propane space heaters: blue flame (convection heat) and orange (infrared). I gather that the convection heater heats the air, while the infrared heater heats nearby objects. Is that accurate?
Thanks
