Jotul Choices
Old 08-26-2015, 02:06 PM   #8
Default Re: Jotul choices
I have a small jotul in my yurt. It works fine, but it is not a big stove and will not heat the yurt up so great at zero degrees.
I used a large cedar pole from a white cedar I cut down to hold the stovepipe in outside the wall of the yurt. I put cement blocks around the base, these are u shaped cement things used to construct chimneys and I held them together using heavy wires. I put ceramic porcelin fixtures along the cedar pole so that the stove pipe can never touch the wood
I put the porcelin in after this pic was taken I believe:
