Ideas To Help Cover Chimney Area Against Rain?
Old 08-31-2012, 06:42 AM   #1
Default Ideas to help cover chimney area against rain?
Hi,
I have recently started living in a yurt in Bulgaria and it's my only home.
I am not bothered about having a window in bad weather so expected just to pull the felt/canvas/cotton package over the whole circular centre piece and be able to have the stove on (Mongolian trad drum). But the canvas around the stove fixings/pipe and metal sheet) burned even though I fixed a pad wrapped in foil around the stove pipe. Not good.
Ideas would be much appreciated. Not a very handy person so some kind of
material to pull over would be best. (Not perspex)
rumbaba is offline   Reply With Quote
Old 08-31-2012, 07:03 AM   #2
Hi, curious if Metalbestos or other double walled type stove pipe is available to you in Bulgaria? It is more expensive, but you only need it a few feet before, and a few feet after, the roof.
I would be VERY concerned if your material is burning, that is definitely not right.
Old 08-31-2012, 12:31 PM   #3
Default Hi Jafo
Thanks for replying.
It is hard to get any but the most basic materials where I am, but your idea seems sound, if only I could get the pipe.
However, as rain is expected soonish, I have today played around with big Bulgarian rooftile, which fits nicely, with a bit of overlap, over the dangerous area which heats up - and will not itself heat up much, if at all.
It seems crazy not to be able to pull the lid over just when I need it against bad weather. When I will also need the stove on..
Old 08-31-2012, 05:22 PM   #4
What are the materials of your yurt, Rumbaba? Is it a traditional, Mongolian yurt, or a North American variety? There is a place in Canada called 'Groovy Yurts' who might have a suggestion for you. They specialize in the Mongolian variety and are located in a cold climate.
It seems that to have to pull the cloth back and forth would be a hassle and not ideal... Perhaps you could try to rig some kind of 'fixed', stationary cover? Stovepipes through the walls reinforced with metal flashing are what we typically do, but I don't know the materials you're using or how much safer that may or may not be. It also helps to have two or even three pipes within pipes for the stove pipe - does that make sense? Then the air between the pipes is a great insulator, preventing the exterior pipe from getting burning hot.
Nomad Shelters in Alaska vent their chimneys through the
. Their set up would be worth checking out as well... Keep us posted!
Old 08-31-2012, 10:07 PM   #5
Default Hi Bill
Really appreciating the ideas coming in.
Yurt is typical Mongolian ger, made in Mongolia. I am Ok with pulling the lid on an off but not OK with the idea of canvas and felt catching fire over wooden spokes! I am living in a yurt because my house burned down..
Realy I just need some sort of material that can not burn to cover the two apertures in the central 'wheel' window - but not metal which could heat up.
Very much like the idea of pipes within pipes, though I think I need to address the rain prob first as we are coming onto what you call fall here..
To see the yurt and the road trip from the UK to bring it to the Balkans, see Castaway Lucy on fb
Old 08-31-2012, 10:29 PM   #6
Froit is a yurt maker in Mongolia, bet he would have some good tips as well, his email address is/was: infofroit.nl
He can take some getting used to... if he's gruff, don't take it personally
But I'd try to contact Yves at grooovy yurts in Canada, his email is: infoyurt.ca
Old 09-01-2012, 06:38 AM   #7
Great idea Melissa! I changed the email links and used the graphic @ symbol you can find in the smilies when making a post. Those SPAM bots come along and harvest email addresses from sites like this one and then deluge the email address. The @ smilie confuses them.
Old 09-01-2012, 08:38 PM   #8
Oh THANK YOU! I hate those spam miners!!!
Old 09-01-2012, 09:15 PM   #9
Dan R-M's Avatar
I am loving your connections, Melissa! It's pretty impressive, actually.
In discussing rocket stoves folks talk about insulating between the two chimney cans with ash. Is that something you think would work? The idea, I guess, is that 1) by trapping the air you limit its circulation and 2) by using ash it's free.
Old 09-05-2012, 06:26 PM   #10
I'm happy to always happy to share what knowledge I've gained with good yurt people! Yurts became a passion and life calling to me, and there are so many others who have had the same experience of finding them, loving them and quickly coming to 'live' them. It's a wonderful community of people, though still not yet 'tightly knit' community. We're getting there! Becky's work did a lot toward that end. So has Bill Coperthwaite's work. The Yurt Maker Gatherings are powerful for that as well, so the scene is evolving!
heating, moisture
