08-25-2023, 11:00 AM
#7
Re: Stove pipe horizontal qn
Straight up.
Think about this. Steam train, paddlewheeler steam boat, oil burning battleship engines, Titanic liner, industrial plant pipes, all exhausts go as straight up as possible. They don't make horizontal runs 'because they draft better horizontally'. lol If they do have a horizontal run it is entirely because other issues with the design preclude a straight vertical exhaust.
That said a yurt wood stove can draft fine with a horizontal run out the side wall and an 90 degree ell. They go sideways due to stack exiting roof and leaking, vs side wall and less likelyhood of a leak. Issue with water leakage at the roof jack in a cloth roof that isn't flashed like on a gabled house roof, not because the horizontal run is 'a superior draft'. Also the less 90 degree bends the better for flow. So yes two 45 degree bends is better flow than one 90. It's all about air friction, and the fact hot air naturally rises it doesn't travel sideways.
Old school carbureted straight 6 engine like my 300 Ford with 90 turn in intake manifold to head and sharp, rough surfaces inside the manifold is the absolute worst for air flow into the engine. Curved intake manifold with as full a curved sweep as possible is absolutely 'THE' best design for multi cylinder carb engine intake. All high performance intake manifolds are curved. End of story. In addition related to friction and flow, 'port and polish' is standard to increase moving air moving through a high performance internal combustion engine, which is basically an air pump. Old school carbed motorcycles the carb is STRAIGHT shot into the cylinder, dang near bolted to it. Small engines like mowers tillers weedwhackers chainsaws etc. do have the carb bolted to the engine. The flow speeds up in the carb, not before.
So straight up is best when possible on a single exhaust. Airplane engines exhaust immediately outside the cowling, they aren't piped to the rear of the fuselage. Exception is exhaust manifold piping on say a high performance V8 with many pipes being smooth curves of various lengths to get the correct back pressure. I'm no engineer but this is very basic stuff.
This took me freeking forever to type, correct typos, edit etc. So....I'M OUTTA HERE on a bicycle ride. Later gator! haha
