05-06-2016, 10:37 AM
#3
Re: windows
Some of this depends on where you are too. If you ever think you are going to use air conditioning, a window is rather necessary. Also, it gives your family another exit in case of fire. Keep in mind, you cannot get out through the walls in a fire. It is either cut a hole in the roof and scale out or go through the door or (if you have a glass window) the window. The standard non-glass windows are barred with lattice.
In hindsight, I would have ordered one glass window. I can retrofit, I just haven't yet.
