Rafter Construction
Old 06-04-2021, 10:14 AM   #1
Default Rafter construction
Hello! I bought a used 30' yurt with 2x4 rafters. I need 2x6 rafters for where I live so I'm going to fabricate new rafters. Does anyone have a template for where the crotches and pins go on a 2x6 rafter? Are the pins the same for 2x4 and 2x6 rafters? For the
ring, it is currently made of 2 layers of 2x6's. I was planning on putting on a third layer so that the width would be correct for a 2x6. Does this sound right?
Thanks!
wildflower698 is offline   Reply With Quote
Old 06-04-2021, 12:42 PM   #2
Default Re: Rafter construction
What brand yurt did you buy?
Old 06-04-2021, 01:43 PM   #3
Fortress yurt
Old 06-04-2021, 02:56 PM   #4
I would contact them, I am sure they would give you the details. It is different for every yurt brand:
https://fortressyurts.com/
Old 06-04-2021, 03:04 PM   #5
I have contacted them repeatedly, with no luck. I was hoping that someone in the community here might be able to provide some insight.
Old 06-04-2021, 04:09 PM   #6
That doesn't surprise me. It took a bit but now I remember those people. Here is a thread in case you were wondering:
https://www.yurtforum.com/forums/yur...-plea-369.html
They have had a rough history of not being the best at customer support. I have no ideas for you other than to perhaps try a local contractor?
The problem is, each yurt is designed differently.
Maybe try to contact them to PURCHASE a single rafter? At least then you could clone it..
Old 06-04-2021, 04:10 PM   #7
Do you happen to live in New England by chance? I know someone who might be able to help you on site if you do.
Old 06-04-2021, 06:08 PM   #8
I do. Please send me the contact info.
Old 06-04-2021, 10:58 PM   #9
A yurt ring made of 3 layers of 2x lumber is 4.5" in thickness. A 2x6 rafter installed on the typical ~25 degree angle of a yurt roof has a plumb cut of about 5.75". Rafters and joists abutting a beam are attached with a joist or rafter anchor. I have seen those used on yurts. Cheap and bombproof install. Rafters are fixed and can not move up down or laterally.
Old 06-05-2021, 04:13 PM   #10
I notice the pin and the crotch are dead center at either end of the 2x4 rafter. I am planning on putting them in the same place of new 2x6 rafter unless anyone suggests otherwise!
fortress yurts
