Platform A Bit To Big. Beams And Blocking Are A Couple Inches Past 30 Foot Circle.
Old 08-21-2017, 02:54 PM   #2
Default Re: Platform a bit to big. Beams and blocking are a couple inches past 30 foot circle
If you got a manufactured yurt from one of the bigger companies then the diameter of the platform is typically very important. It doesn't seem like it until you figure circumference, then consider that the roof is typically cut very precisely as are the walls. My advice would be to cut the beams back. Get it right now or you will have a can of worms pretty quickly.
