Old 09-08-2015, 09:31 AM   #381
I have some...what for?
Old 09-08-2015, 09:33 AM   #382
Soapstone is known for it's heat retention and release properties:
Soapstone: The soft rock with incredible heat properties!
That's why many stove manufacturers use it to line their stoves with.
Old 09-08-2015, 10:21 AM   #383
Interesting, thanks. I think I've heard about the Innuits linig their firepits with it. I have rather small pieces, that I use for carving various historical stuff. Not sure if I could find any large blocks around.
Old 09-08-2015, 10:50 AM   #384
I have it inside and outside of my stone. It stays warm long after the fire goes out.
Old 09-08-2015, 04:50 PM   #385
Knecht I like the wall lattice to deck anchors.
Old 09-08-2015, 04:58 PM   #386
My dinky little 'insert' style wood stove was lined with fire brick bottom sides and back. I pitched it to make the sove volume somewhat bigger. Big mistake. Less mass, and the bottom of the stove warped enough to put a bind on the air intake control. What a dolt. lol
Old 09-09-2015, 06:07 PM   #387
BTW, here is my updated stove pipe:
Old 09-10-2015, 12:34 AM   #388
Nice. Putting a pipe through wall makes some things much easier, though it requires well prepared wall section for that.
Old 09-21-2015, 09:21 AM   #389
If you have a traditional one room yurt, as I do, a stove in the middle is advantageous in terms of even heat distribution throughout the yurt. That's a big deal if you have a drafty poorly insulated and sealed yurt like mine. However a side placement is out of the way. A wood stove in a home is rarely situated in the center of the room.
Old 09-21-2015, 07:54 PM   #390
I found out my stove is great if you like roasted sausage for supper.
Which I do! The large door is just above the fire grid, makes roasting easy.
