Conversion Of A Canvas Yurt To A Permanent Structure.
Old 02-08-2017, 07:01 PM   #1
Default Conversion of a canvas yurt to a permanent structure.
Hi YurtForum!
I'm about to be the new owner of a 30' yurt (manufacturer unknown) here in Hawaii. The yurt canvas is all moldy and has a few rat-holes chewed through it, so I'm starting to examine my options for converting it to a more permanent structure (ie. no canvas).
I've been reading through these forums and have found some great tips and suggestions, but still need some specifics cleared up in my head before I make a final plan.
I've been told that I can use something called "SmartBoard" as siding, and frame in windows quite easily. I was told that I'd just remove the canvas and (optionally) the lattice, then screw in the "Smartboard" just like normal siding. Does anyone have experience using this material? Tips/Suggestions?
The yurt does have the redwood "stud" package as a friend called it so framing in windows should be pretty straightforward, but any tips/pointers on that would be appreciated to.
Additionally, I'm starting to research and get quotes for custom metal yurt roofing, but it seems like shipping cost is going to be prohibitively expensive here in Hawaii. Is is a bad idea to simply slap some additional struts between the existing 2x6 redwood rafters and lay down a plywood/asphalt shingle roof?
Anyhow, if anyone has any pointers or tips, I'd be happy to have them as I embark on this new project.
Thanks in advance!
mgeekwai is offline   Reply With Quote
