07-22-2016, 06:23 PM
#8
Re: Electrical Outlet Placement
No I don't. Somewhat related, temporary power on a jobsite is frequently 2- four receptacle boxes, and 2- 20 amp breakers, mounted at ~4' height on a pole. That is generally satisfactory until the permanent power is installed into the panel inside the new home. And then if you are lucky, there will be three duplex receptacles on three seperate 15A breakers, or 'real lucky', 20A breakers. Unfortunately, and frustratingly, tripping those is a regular occurance in residential construction. All I can say is watch your amp draw. If I lost a refer full of food that would be a financial hit that would be a REAL pisser. Wish I had real advice here on this, but I do not. Good luck.
