Old 10-30-2014, 04:18 PM   #121
Today we finished attaching the other khana end to the frame, rotated the whole thing a bit to get the door where desired and then anchored it to the floor. Did some measuring and have the roof height planned, so I can start making the baganas.
Old 10-30-2014, 07:50 PM   #122
That yurt ain't goin' nowhere with the L anchors. Good move.
Old 10-31-2014, 01:08 PM   #123
Main parts of the baganas finished, though both ends will get the T-bar yet reinforced by slant braces. First testing with the ring temporarily ductaped.
Couple roof rafters added to mark the hole angle on the ring.
Old 10-31-2014, 05:21 PM   #124
One reinforcement done:
Old 10-31-2014, 09:36 PM   #125
You are doing a great job love the pictures of your progress.
Old 11-01-2014, 11:06 AM   #126
That's right Marshall. This build along is the 'meat and potatoes' for yurt construction archives. Apply yourself, and you too can do it. Good stuff all around.
Old 11-01-2014, 12:18 PM   #127
Thank you guys. I have both baganas finished and reinforced on each end and tonight I'm starting with the ring holes.
Old 11-01-2014, 12:48 PM   #128
Yes Bob i have the frame in my icon was number 2 for me and it became a very nice green house. just change the cover. I have built 3 total. I still have my first tucked away in a safe place for when needed.
Old 11-02-2014, 01:47 PM   #129
Another testing, now with finished baganas and some of the slots in the ring already cut.
We still need to put the
tension cable
over khana top, as you can see it's a bit deformed. Already have the cable and clamps, though I yet have to think of a way to lead it over the door frame. Other than that, the whole thing seems to come together nicely.
Old 11-02-2014, 08:50 PM   #130
It IS coming together nicely. Don't worry about how to run the cable over the door. Make the cable to length. Lay the cable in the crosses and right across the top of the door frame. Drill holes in your rafters near the lath cross and lash the rafter to the frame, and at the same time you'll lash the cable to the frame. Nothings going anywhere if you lash the rafters down to the frame like I did. Bombproof.
