Replacing Bender On A Colorado Yurt
Old 08-16-2017, 09:50 AM   #1
Default replacing bender on a Colorado yurt
We have a 24 ft Colorado yurt with two doors. About 1/4 of our bender board which holds lattice on the bottom in place has rotted out because of
. It needs to be replaced. Anybody done this or know how to do it? Do we need to take down the canvas sides or can we just lift them. Also I am wondering if instead of making another wooden bender if we can replace the wooden bender board with something that won't rot like plastic or aluminum so we don't run into this problem again. Appreciate any input.
walking is offline   Reply With Quote
Old 08-17-2017, 09:30 PM   #2
Default Re: replacing bender on a Colorado yurt
i recommend doing it a piece at a time. this way the latice stays in place.
nomadyurt is offline   Reply With Quote
Old 08-18-2017, 07:02 AM   #3
Agreed, one piece at a time. Did you paint your board last time?
Old 08-21-2017, 10:11 AM   #4
Plywood or OSB, or whatever, replace in sections. I'd prepaint it for certain.
Old 08-21-2017, 02:58 PM   #5
This is very easy. Get the new benderboard that Colorado Yurt offers. It is a composite, nice high quality. Then remove the wall connections only at the door slats and the bottom grommets. That will give you plenty of room to work. Then replace the boards in quarters around the bottom, use stainless steel screws. Voila! Have fun.
Melissa
Wintergreen282 likes this.
