Welded Steel Ring?
Old 01-22-2014, 12:35 AM   #1
Default Welded steel ring?
I would like to build a 30 foot Yurt to be a semi / permanent structure to augment a cramped RV. My question is about the
center ring
. Is there any reason I should not fabricate this out of steel? I was thinking of using a length of channel iron as a bracket for each rafter, possibly securing the rafter to the ring with a bolt or two. I'm not terribly concerned about authenticity or weight (I plan on supporting the ring with an H). What elsw should I keep in mind?
Almosthomeless is offline   Reply With Quote
Old 01-22-2014, 12:52 AM   #2
Default Re: Welded steel ring?
I have seen several yurts with Steel and composite rings.
Asheville Yurt Company
comes to mind. I saw other pics, but here is one I found online:
I have even heard of people using old tractor rims for the
center ring
, but never heard how they turned out.
Old 01-30-2014, 11:30 AM   #3
dennishl's Avatar
I use a welded ring. I had the basic ring fabricated at a local shop and then welded on a few pockets to receive the roof poles. We've had over 200 inches of snow so far this year. No problems at all, as far as snow goes. My yurt pics are in the members yurt section if you want to take a look.
Old 12-19-2014, 05:29 PM   #4
Not sure if this topic is current still but we've been using steel and aluminum rings for quite some time. Have a look at our website for newer designs too.
Nate
Asheville Yurt Company is offline   Reply With Quote
