Insulation
Old 09-08-2012, 08:18 AM   #5
Default Insulation
I have the full snow load package which means 2x4's under each 2x6 rafter. Securely attached to each rafter and the floor. I have been in the yurt with 75 mph winds and only heard some creaking over one window~ I have real windows. Also my floor is insulated with 2" of foam board between the floor joists
Back to insulation~ mostly I have thought about using foam board but wanted a snugger (?) fit. Also the work of fitting the foam board between each rafter seems like a lot of work. One writer on this forum wrote about using denim insulation between her rafters and on the wall and reported only using 1 1/2 cords of wood
I went through 5 cords last winter and wasnt in the yurt for almost a month .
I dont mind when the temps are in the 50's in the yurt at night but going through so much wood really gets my goat!
I am going to try denim or roxul but then want to cover them. I dont think covering with fabric makes sense insulation-wise so I am considering using wood of some type. I am just concerned about the weight on the rafters and the wire that supports the whole roof.
I tried heavy curtains on the walls, even added another layer of reflectix to my north walls and only used my south exposed door last winter.
One other company that I spoke with talked about using quilt batting~ you can get it in various sizes~ it doesnt absorb
I researched online the cost of 2" of this type of material and it was not cheap~ even buying in bulk.
There is one couple in NC that used foam board~due to town regs and it looks awesome.
I live alone so doing some of these 2 person projects become a challenge.
I am also putting on storm doors as that was a big heat loss area as well as the dome~ which I put 4mil plastic over (on the inside)and held on with the velcroe with the bug screen. It helped some
Has anyone tried the foam board?
Any insulation is a good investment if one is living full time~ even this summer with all my windows open (6 ) it would get up to 100 so I left the doors open~praying that no bears (I am surrounded by berries) or other critters ventured in.
Thanks to listening to my ramblings
Corina
