Old 10-26-2014, 11:31 AM   #11
Thanks. Now that's all easy to make stuff, no problem. I think the ring there is arc welded. I'd make a forge weld, if going for authenticity. Not sure, but the bolt that ring itself is attached to, also seems to be welded on something (most likely a woodscrew). This could be made as a split pin that goes through the board and then the "legs" are bent sideways. Various latches and hinges are also possible.
