Permitting A Yurt
Old 07-23-2012, 12:57 AM   #1
Checklist for permitting your yurt:
  • If your yurt manufacturer has any stamped engineering designs, have copies of them handy.
  • Information on snow load, fire rating of materials, and R value of the insulation(s). Find a local, licensed architect to review your platform plans and give his wet stamp. The local architect or a plans router will route them through the system. These services are usually fairly cheap in the scheme of things, and WELL worth not bungling it up as an inexperienced building department novice.
  • Warranty information on materials (i.e. roof).
  • Does the design meet IBC code?
  • Are there any other yurts in your area? If so, ask the owners what process they went through to get a permit.
  • Tall walls, 6'9" or higher at the door are generally required for permanent structures.
  • astrofoil doesn't meet r-value codes in some areas. Ask the manufacturer for
  • Egress is a common requirement, so an extra door or an operable window may be needed.
  • For a residence or detached bedroom or anything with plumbing, you will also need wastewater plans. Engineered septic or cesspool designs or plans showing how you will route into an existing system.
  • For a residence you will need to show your water supply, refrigeration, cooking means and a shower/toilet/sink. You will need to provide a floor plan and a full site plan, locating your waste water, set backs, driveway and house/yurt.
  • If it is not a residence, then get the help of a local router and make sure it is called something else. Most places will not allow two full kitchens to be on one property, thereby making for two full residences. You can have partial kitchens, but typically only a single sink (not a double chamber) and a hot plate or the like.
Old 09-10-2012, 09:57 AM   #2
I have made the first post of this thread that Melissa started a checklist of what you should need when starting the permitting process. Please feel free to suggest other items for the list.
HawaiiYurts and dchanmer like this.
Old 09-13-2012, 02:38 PM   #3
Wind kits are a good upgrade to get in a yurt, even if you aren't in a windy area. The posts allow for electric outlets and switches to be placed at convenient heights and wire for overhead lighting can easily be trimmed out along the posts.
For permits you will need the following:
-Tall walls, 6'9" or higher at the door.
-astrofoil doesn't meet r-value codes. Ask the manufacturer for
-Egress is a common requirement, so an extra door or an operable window will be needed.
-Fire ratings
-Architect stamps (find a local, licensed architect to review your platform plans and give his wet stamp. The local architect or a plans router will route them through the system. These services are usually fairly cheap in the scheme of things, and WELL worth not bungling it up as an inexperienced building department novice).
-For a residence or detached bedroom or anything with plumbing, you will also need wastewater plans. Engineered septic or cesspool designs or plans showing how you will route into an existing system.
-For a residence you will need to show your water supply, refrigeration, cooking means and a shower/toilet/sink. You will need to provide a floor plan and a full site plan, locating your waste water, set backs, driveway and house/yurt.
-If it is not a residence, then get the help of a local router and make sure it is called something else. Most places will not allow two full kitchens to be on one property, thereby making for two full residences. You can have partial kitchens, but typically only a single sink (not a double chamber) and a hot plate or the like.
That should be enough to get started...
dchanmer likes this.
Old 09-17-2012, 10:18 AM   #4
Thanks Melissa, I have updated the first post in this thread. I think it is coming along nicely!
Old 10-20-2012, 07:43 AM   #5
Found this link:
Can a yurt be built…legally…as a primary residence?
Abstract is offline   Reply With Quote
Old 11-26-2012, 12:48 AM   #6
lizsteve -
i've read posts like yours on the small cabin forums - if they had to enforce the insulation rule not sure much would get built. bummer about the septic requirement and no graywater, even after you had a composting toilet.
thanks for sharing.
Old 12-11-2012, 03:36 PM   #7
lizsteve,
Question: Are you sure you can't have an engineered/stamped gray water system along with a composting toilet? That's what code says here, and they were sticklers about anything other than cesspool or septic until recently. Just a thought. In my experience, the graywater engineered filtration was about as much as a septic anyway when it was all said and done. Danged if you do, danged if you don't!
Old 12-11-2012, 11:09 PM   #8
Thanks, but here, it's county to county dependent. The county literally across the street from us does approve grey water systems if they are drawn by an engineer. but our county does not have an engineer on staff to design or approve apparently. We asked if we could hire the neighboring county engineer to design it and get it approved by the state DEC, but we were told no.
As far as composting toilets, the only one that can be approved here is the commercial SunMar or similar.
There are some details we have figured out that I'm not comfortable posting here. But it seems there is some wiggle room in the system if people are creative and smart.
Peacefirst likes this.
Old 05-10-2022, 12:31 AM   #9
Default Re: Permitting a yurt
Getting a yurt permitted seems to be a grey area to talk about... I see them all over Washington for rent (by govt) yet for some reason it's near impossible to figure out how to get permitted!
I guess that is exactly why so many opt to build and permit later (if discovered). Makes sense, but for those that want to permit then build, what?
Uknaqin is offline   Reply With Quote
Old 02-18-2013, 08:13 PM   #10
In New York State, greywater has to be treated in a certified septic system. This is stupid, but the rules. They allow composting toilets, but only commercial certified models and say that the waste has to be disposed of in a septic system of landfill.
All that and still the New York State Department of Environmental Protection (DEP) has a website telling people to use greywater systems and how great they are. So you conflicting opinions, but the health codes apparently pull rank in this case.
Dorishaktiblue likes this.
moisture, naya
