Bottom Of Floor?
Old 09-01-2016, 06:53 AM   #1
Default Bottom of floor?
Hello folks,
Getting ready to build the floor now. I'm a bit concerned with most plans having an open or exposed bottom to the floor, i.e nothing under the the circle of joists. Most plans call for joists, 2X4s for floor joists, 2" foam
, then floor.
Has anyone put anything on the bottom? I was thinking 1/4" PT ply circle to make a sandwich, but not liking the extra expense this is going to run. 6mm poly wrap maybe?
Also, when attaching the 2X4s do most people just toenail them or use Simpson brackets?
rangeroad is offline   Reply With Quote
Old 09-02-2016, 09:26 PM   #2
Default Re: Bottom of floor?
I would go the extra for the sandwich. For one you will want the
. Also it will keep critters from nibbling on your insulation.
Delores is offline   Reply With Quote
