? Being Approved The Yurt Under The California Building Code
Old 09-21-2015, 10:53 PM   #1
Default ? Being approved the yurt under the California Building Code
Anyone has been approve the yurt as residence under the California Building Code? I need your help. If you can tell me how your jurisdiction approved your permit, please let me know. Then I can tell the building department here to completed my project. Many thanks!
tundra87 is offline   Reply With Quote
Old 09-27-2015, 02:15 PM   #2
Default Re: ? Being approved the yurt under the California Building Code
i was approved as a permanent residence in Montana. Had to put in
which meant the design had to change a bit. We bought through
Shelter Designs
. But I did the GC and the building permit work.
Eilmcg is offline   Reply With Quote
Old 12-30-2015, 02:19 AM   #3
Hi tundra87! I was wondering if you've had any luck permitting your yurt. My husband and I have the same questions/concerns and any insight/tips you can provide would be greatly appreciate it! You mentioned that yours is in Joshua Tree…we want to build ours in LA. Thanks so much! ~ Mabel
mblung is offline   Reply With Quote
Old 01-01-2016, 07:29 PM   #4
Mabel - I posted a reply in to your other post, also. a yurt from a reputable company will easily meet all the building permit requirements (you will need an engineer approval). the only thing that will hold you up is the
. as i said in my other post, we changed the design slighly and were able to do it in Montana where the requirements are even higher. Send me a private message if you'd like to talk more about it.
