-   -   ? Being approved the yurt under the California Building Code (https://www.yurtforum.com/forums/building-a-yurt-f3/being-approved-the-yurt-under-the-california-building-code-1016.html)
tundra87 09-21-2015 10:53 PM
Anyone has been approve the yurt as residence under the California Building Code? I need your help. If you can tell me how your jurisdiction approved your permit, please let me know. Then I can tell the building department here to completed my project. Many thanks!
Eilmcg 09-27-2015 02:15 PM
Re: ? Being approved the yurt under the California Building Code
i was approved as a permanent residence in Montana. Had to put in insulation which meant the design had to change a bit. We bought through Shelter Designs. But I did the GC and the building permit work.
mblung 12-30-2015 02:19 AM
Hi tundra87! I was wondering if you've had any luck permitting your yurt. My husband and I have the same questions/concerns and any insight/tips you can provide would be greatly appreciate it! You mentioned that yours is in Joshua Tree…we want to build ours in LA. Thanks so much! ~ Mabel
Eilmcg 01-01-2016 07:29 PM
Mabel - I posted a reply in to your other post, also. a yurt from a reputable company will easily meet all the building permit requirements (you will need an engineer approval). the only thing that will hold you up is the insulation. as i said in my other post, we changed the design slighly and were able to do it in Montana where the requirements are even higher. Send me a private message if you'd like to talk more about it.
