24' Yurt On A Concrete Pad? Hydronic Heat?
Old 03-30-2015, 04:07 PM   #2
Default Re: 24' yurt on a concrete pad? hydronic heat?
Many of the state parks use concrete pads. You will have to anchor the walls to the pad, but with a masonry bit, no problem. Keep this in mind with your pex. You don't want to accidentally puncture the lines when running screws.
Consider the water runoff from the yurt. You will definitely want that water to run away from the yurt, so consider your grades AROUND the yurt base.
I think you have a great idea.
hierony likes this.
