Ok, I finished the floor grid today and got some planks to start covering it tomorrow.
I'm a bit worried about my khana. Can't find any right dimensioned laths around and will be ordering them made at local sawmill. Obviously don't want to make any mistake and end up with a load of useless wood. The yurt shall have 6m diameter (about 20ft if I'm not mistaken) and I need the khana to be 150cm high (60"). Reading various instructions and tips and checking what dimensions of lumber is available around my new location, I chose the dimensions of my khana planks to be about 220cm long (88"), 14x42mm (.56x1.68"), 9 holes in each, forming 90°squares, side of the square being 23cm (9.2"). After some calculations, it should be about 108 khana planks, give or take (depends on final door size and such). Does it look correct? Or do I have too many laths in my khana, shall I reduce the counts and make the squares larger?
