The device behind the stove is a spark trap. The whole set is army surplus, likely made in 50's or so. It was made for large army tents and various semi-permanent installations. Very primitive design, all cast iron, no linig. On the other hand, there's very little to break on it. I don't really mind the extra room it takes, it hardly sticks out of the bagana area. Plus it surely helps to keep some of the heat in. I saw pics of some other Czech's yurt, that guy also used this stove setup and had couple bricks stacked on each side of the spark trap, to accumulate more heat. Maybe in winter, I'll do it as well.
The trick to heat the pipes is nothing new, really. It was a common thing back when woodstoves were in every house. Many blacksmiths also use it, to get the draft started when they fire up the forge (I have an outdoor forge without chimney, so I don't have to)
