The reason we wrap the wall canvas around the door post and attach to the lattice on the inside is because even though “boat shrunk” Sunforger canvas is supposed to be pre shrunk, it isn’t. It will shrink the first few times it gets wet and so if it was secured to the door posts, it woukd get very tight, be under a lot of stress and squeeze the lattice.
With the lattice wrapped around the door posts, it provides about 10-12” of adjustment.
In the instructions, it showed drilling round holes outboard of the door post tenons in the threshold and header. In our door canvas we sew two “tubes” to the outer most edge. Inside these go 3/4” dowels and they then fitted into the holes in the header and threshold.
You could put a door frame within the door frame, to which you could screw in hinges to attach a wood door.
The wood doors I sometimes sell use pivot pins like those used in bifold doors and so the doors swing on these. With a door frame within a door frame, it will allow you to add a jam to keep the draft out.
There are always compromises especially with canvas. Vinyl is great as it last longer, you don’t have to hem cut edges and it doesn’t shrink. A lot of advantages, but I would only use it in permanent type yurts as its harder to pack up fold up is more heavy and bulky. Not ideal for a camping yurt.
