Ground Cover/footprint Materials
Old 06-24-2019, 05:00 PM   #1
Default Ground cover/footprint materials
Hi, I'm wondering about inexpensive materials for ground cover below my platform (which will be hay bale for now). I'm in the wet part of the PNW. Is there any reason not to do billboard tarp? What else should I lay down below the platform in addition?
Thanks.
Pucks_poppy is offline   Reply With Quote
Old 06-25-2019, 08:03 AM   #2
Default Re: Ground cover/footprint materials
I would not lay anything under the platform except maybe some crushed stone if you have any. A tarp will be an ideal places for critters to live such as mice.
Old 06-25-2019, 01:33 PM   #3
Hi, thanks for your response. So you are saying that below the hay bales wrapped in tarp, I should only put gravel, and not another tarp, right? How about between the hay bales and the sub-flooring?
Old 06-25-2019, 03:17 PM   #4
I am not an expert when it comes to using bales. AFAIK people put their flooring right on top of the bales, but I have no experience with that.
Old 06-26-2019, 08:27 AM   #5
There used to be a guy that posted here that set his yurt on hay bale. hierony or heirony You might pm him. I have no advice or comments about your question because I haven't done it. Good luck.
