Compression Ring Woes
Old 05-16-2022, 05:45 AM   #1
Default Compression ring woes
Hi, everyone. I live in the Samarian mountains in Israel and am building a yurt for a guest room/home office. I'm following this plan: https://www.pbm.com/~lindahl/articles/yurt/
which suggests 36 rafters. The problem is that I've started putting the
center ring
together and am only coming up with 21 slots. See picture attached.
Is it ok if I only use 21 rafters? Do I need to change the ring size? Should I rebuild with thinner spacers?
Baruch is offline   Reply With Quote
Old 05-16-2022, 04:20 PM   #2
Default Re: Compression ring woes
I built all three of my yurts using that basic plan. I wouldn't go with 21 on a 16' yurt the rafters won't line up on the lath crosses. Go with 36 like in the plan. Or, if you want to go light for camping, make the ring with 18 slots instead of 36, and just use 18 rafters on every other wall cross.
Forget the 1x4 spacers they need to be beveled to get 36 slots. Bad design. Use 4x4 that's ripped to rafter width in one dimension. If the rafters are 2.75" width, make the spacer blocks out of 4x4 ripped to 2.75, on one side. Use a miterbox/chopsaw to cut the 5 degree bevels each block. That allows plenty of clearance at the inside or the ring. It's GOTTA be beveled to work. 360/36 = 10. 10/ 2 = 5 degrees each side of each block. It the rafters are 1x or 3/4" wide, allow 13/16ths for slot width.
To lay out 30" dia. ring with 36 slots. 30 x 3.14 = 94.2. circumference. 94.2 /36 = [2.61] width per slot at the outside of the ring. subtract width of rafter, .75" plus 1/16th for clearance, that's .82.
So 2.61"- .82" =1.79 block width at outside ring. Cut 5 degree bevel on each side of the ripped 4x4, with the rafter width horizontal on the chopsaw table, nor vertical.
There's your spacer blocks. Lay out the plywood ring in 36 segments, 2.61 apart at the outside edge. The last gap will assuredly be slightly off so just fudge the layout back over ten slots or so. Tack and glue the blocks to one piece of plywood. Flip it over drill pilot holes and screw the ring and blocks together. Flip over glue and screw the second ring.
OR -what you REALLY need to do- just get the freekin plan to a carpenter. He can build the ring for you.
Pics of my 16' yurt are on google images.
Bob Rowlands homemade yurt
Mines the green one with rafter stashed either side of the green door. There's a pic or two there of the ring. You'll see there are no 1x4 blocks in the ring.
That is the plan you are using with three mods on the ring, door frame, and joining the wall sections. By God whatever you do, 'do not' use bolts to join the two wall sections! You'll be cussing like a carpenter trying to get the wall together I guarantee. Lap and lash like Mongolians do. You need to make one of the wall sections, one bay longer for the overlap. If you build three wall sections make two one bay wider. You need one bay extra per section overlap.
Good luck. Keep in mind it's a yurt not a rocket. You'll get it. Have a carpenter buddy help you.
Old 05-16-2022, 05:07 PM   #3
That's my record post for the yurt forum. Nobody can say I don't give a damn. haha
Old 05-16-2022, 08:29 PM   #4
Thanks Jafo.
Another point on this particular yurt plan. To properly tension the yurt - rafters snugged tight in their slots, and alternatively no flop in the ring- I made a
tension cable
to lay in the lath crosses, from cheap plastic coasted 3/16ths cable and three cable clamps.
I figured the circumference of the yurt-which btw is actually 15'9" not 16'- and lapped and cable clamped the ends so I had exact circumferential wall length. Prebuilding the cable allows you to just drop it in place once the wall sections are lashed, and wall is attached either side of the door frame. I adjusted that by eye so you see squares in the laths, not diamonds. I cut the notches in the rafters very slightly deeper to accommodate the cable.
Once the cable is dropped in the lath crosses, and run across the top of door frame, and secure it to the frame with a length of cordage. Next install the rafters. As the last few get installed in the ring, BAM SON! the yurt is >>perfectly<< tensioned. Rafters tight in the slots, and no up and down slop. There's no blasted fiddly farting around adjusting the wall diameter while installing the rafters. No rafters bop you on the head, no inversion, no finding you can't force the last few rafters in place. The pre built cable eliminates all that. Plus it is incredibly strong. I'm well over 200 lbs and can hang from the frame with no vertical deflection. Solid as hell.
Just sayin. This works -perfectly- for me. I fought the rafter install on the initial set up. Rafters hit me on the head and scratched me. YOU DIRTY SUMBIT%$! haha Once was enough. I used reason and 'VOILA!' a solution that worked perfectly on all three yurts. Anyway there you go.
