Montanafront2012
Good Afternoon,
I have had a 24 ft Yurt in Northern Vt since 2013. This Spring I have experienced some settling of the platform support posts into the ground.
The platform is supported by 4X4's sitting on poured concrete grade level bases. I did not have a level with me but I guessing the settle was 3-4 inches. (see attached pictures, the picture of the yurt itself is from years ago so you can see the terrain)
I am not sure why this happened after 7 years. The land to the south and west is higher elevation so I believe this is caused by moisture/freeze-thaw.
I was thinking that I would rent/buy a jack, jack up the platform post by post, then replace with a longer 4X4 post to account for the settle.
Any thoughts on this subject would be greatly appreciated.
If I can get the platform back to level I need to think about a way to keep moisture away from the area containing the supports.
Best Regards,
Peter M
Best Regards,
Peter M
