Knecht
Ok, thought I'll show you the saw. It's just a quick made one, more like survival style, but it works perfect. Side bars are made of rose hip branch, that wood will crack lengthwise but won't break. This one has been drying for several years now, so it's good and ready. Should last a lifetime. Make sure to pick some when clearing a rose hip bush, this thing makes great canes, clubs and shafts (if you don't mind the lengthwise cracks, but you can always wrap the handle with something). Middle bar is just a copper pipe leftover I grabbed for this, as it had the exact length I needed. Just flattened the ends a little and chiseled a pocket for them in each of the side bars. Top tightening bundle is made of tarred bankline, shouldn't break and shouldn't care about moisture. Blade is Bahco drywood blade, brand new. Bahco makes good saws. The blade is the only part I had to buy to make myself a perfect handsaw. Guess I'll have to replace the copper pipe with something sturdier, as it's likely gonna bend at the ends, but should last long enough to help me in the yurt finishing. Then I'll either use some good hardwood or iron pipe.
