We live in Northwestern Ontario and have recently moved into a 32’ yurt. We are battling the condensation issue inside. Moisture collects on the inside of the dome, then rains down on us. We heat with propane, so when it gets cold, it’s too expensive to open the dome and let the heat out. We have real windows, but even leaving a couple of them open a bit, doesn’t seem to help. We have put a fan near the peak, have run a de-humidifier and have tried putting bubble wrap up there as insulation. Nothing worked. It continued to “rain” inside the yurt. We don’t plan to live in the yurt most of the winter, but would like to if need be. I was wondering if you think a custom, 2 or 3 pane plexiglass window might help? It would be constructed so that it would be removable, and fit over the dome opening inside the yurt. You said that 2” styrofoam worked, but you lost the light. Would a double or triple pane “window “ insulate as well as the 2” styrofoam? The humidity in the yurt is not very high. I have even put a humidistat up inside the dome, and it isn’t overly high. The windows never have condensation, only the dome, which then rains down onto the furniture, the floor and anyone sitting on the furniture. When you used the styrofoam, was there frost buildup on the dome side of it? Did you leave the dome open a bit once the styrofoam was installed? Are you and your family still living in the yurt? Thanks!
