I notice you are in Little Falls, NY which means that using only wood heat with traditional plumbing in the winter will be a full-time occupation and one that will tether you to the yurt. You won't be able to leave for more than ~12 hours at a time without pipe freeze up (I know from experience). Also, (if you are off the grid) AC electric pipe heaters will suck your battery power down in a matter of hours.
My way of solving this was to throw out my old view of plumbing and replace it with something more yurt friendly & much less expensive. What I would do is to support the countertops with 55 gallon barrels which will hold your winter water supply. If you are not using a flush toilet, I've found that about 5 of these barrels (~250 gal.) per full-time dweller is enough to get through the winter. Once you fill up your barrels in Nov-Dec you can use a 12 volt pump from them to either fill a gravity barrel which you would have elevated on the counter top for cold water , for hot water you can pump directly to a tank-less water heater (LP) and then route that to your sink and/or shower.
If and when you need to leave for a few days just make sure your lines are purged, your drains are pickled, and the barrels aren't so full that they will bulge up when frozen.
-Cheers
