Cold Weather Report 2017
Hierony, I put the that foam weatherstripping between my walls and platform before I screwed the wall to it. That helped a lot with draft.
I believe it was 1 inch foam.
We have just ordered a 32' yurt from Yurtz by Design. We live in Northwestern Ontario, and plan to live in the yurt. We will be using foam insulation in the platform, but I am wondering if we should also install foam weather stripping between the walls and the platform to eliminate any drafts? Thanks.
I did that on mine and it does help. If you are going to use a wood stove, one of the big things you can do is to vent combustion air from outside.
