Compression Ring Not Level
Old 03-23-2020, 02:05 PM   #1
Default Compression ring not level
Hi,
I'm pitching a 30' Colorado yurt in Hawaii, and I just noticed that the compression ring isn't level.
Can I loosen the rafter bolts and shift it even though the roof is already on? I think it may have happened when we got the heavy roof up there, the bolts may not have been tightened enough. It's not by too much, but it's visible. Maybe a 2" differ from one side to the other. The
isn't installed yet.
Can it be fixed without the roof caving in on me??
Appreciate any advice!
Helena is offline   Reply With Quote
Old 03-23-2020, 03:10 PM   #2
Default Re: Compression ring not level
Yes you should be able to do that.
Dan
Helena likes this.
dtmeihls is offline   Reply With Quote
Old 03-23-2020, 03:25 PM   #3
Yes, you can. Be sure to make those nuts extra tight once it's level so it doesn't happen again.
Where in Hawaii?
Aloha!
Helena likes this.
Old 03-23-2020, 03:40 PM   #4
Where in Hawaii?
Aloha!
Thank you! Yes, I’ll tighten them better this time!
I’m on the Big Island, Laupahoehoe!
Sent from my iPhone using Tapatalk
Old 03-23-2020, 04:02 PM   #5
Ahh, beautiful area for a yurt ��
We are the Colorado Yurt Distributor in Hawaii, you can always call us for advice if you need! Was this Linda's yurt? Call if need, my cell808)895-8640.
Mahalo! Happy Yurting!
Melissa, Yurts of Hawaii
YurterRT likes this.
Old 03-23-2020, 04:06 PM   #6
Yes, it was Linda’s.
Thank you so much, I’ll try to fix this and will keep your number if I run into more issues!
colorado yurts
