-   -   Tankless water heater recommendations (https://www.yurtforum.com/forums/yurt-living-f2/tankless-water-heater-recommendations-1364.html)
Jafo 05-04-2020 07:33 AM
Re: Tankless water heater recommendations
Yes, here is the heater and pump separately:
https://amzn.to/2Ywm2Ad
https://amzn.to/3b3lSTM
alyssam 05-06-2020 02:16 PM
Thank you so much for the speedy reply. Do you have your yurt somewhere it freezes? That's the water heater I was looking at initially but we would like to use it inside, do you use yours outside? Trying to figure out a safe way to use a propane tankless inside (not sure best way to vent to outside) where we can just use a hose really. Seems like these would be perfect except they say to use outside.
Jafo 05-06-2020 03:08 PM
Yes, it gets down to -35 here in the winter. I used it inside. When I am not there (it is my camp, not my home) I put non-toxic RV antifreeze in it.
alyssam 05-08-2020 01:12 PM
do you vent it or did you just hook it up inside? thanks!
Jafo 05-09-2020 05:19 PM
I just hooked it up inside. The longest it runs is about 1 minute when I fill up the sink to do dishes. I have another in our shower yurt and I usually run that with the door open.
johnsonrdn 10-18-2021 07:46 AM
ECOTOUCH ECO55, I would recommend this water heater to anyone. Installed for my shower in our little house and it amazes me how well it works. I mounted it under the building near the shower and operated remotely through the floor.
johnsonrdn 10-30-2021 08:33 AM
It uses 220 volts instead of propane and only heats water as needed as required. Overall I am very impressed.
