-   Yurt Plans (https://www.yurtforum.com/forums/yurt-plans-f22/)
-   -   Planning a forty foot yurt, check out my CAD design! (https://www.yurtforum.com/forums/yurt-plans-f22/planning-a-forty-foot-yurt-check-out-my-cad-design-1239.html)
EGEW 01-07-2017 04:14 PM
9 Attachment(s)
Hello All!
My name is Evan, I've been lurking about on the forum for a few weeks now. I finally registered today and figured I would share what I've been planning and seek help/guidance from y'all. Please feel free to provide any advice!
I'm in colorado, I am yet to acquire land for the yurt, but it will probably be in colorado, or somewhere with similar heavy snow loads. I have two years left on my current apartment lease. I'm planning on building the whole the thing... slowly. Many trips to home-depot are in my future.
What I'm pretty sure about:
40 foot diameter
~7 ft walls
Larger toono, more windows.
lots more to type, will do so in follow ups. lets see if I can get some images attached....
hierony 01-07-2017 08:42 PM
Re: Planning a forty foot yurt, check out my CAD design!
Impressive! That will be one giant of a yurt--I hope you don't plan on moving it often :p
My yurt is nice & drafty (for the moment)--I would hate to heat a very drafty 1300 sq ft...
I'd also suggest being very careful about your membrane materials. Natural cotton is nice for breathability, but can wick moisture inwards if you're melting the snow off--it'll also degrade over 5 or so years. You'll probably use more modern material though. Also think about getting your canvas up there: the cotton canvas for my 20 ft yurt weighs 100-120 lbs, yours will be substantially heavier. Sewing it together will be quite the chore.
You're obviously thinking about snow loads--I like your four center columns. Any idea if you're 2x4 wall supports will need bracing to prevent buckling? I'd also be curious about the footing load.
With as much materials as you'd be using, it might be worth finding the local mill and getting a bundle or two of what you need direct. At least I've seen it done in my area.
Ask lots of questions & post lots of pics. Good luck!
EGEW 01-07-2017 09:36 PM
part2
Attachment 965Since I have time on my side, I'll be updating this design and posting here as I do so. And i'll be explaining why!
I would probably just buy a 40 ft yurt... but they are just a bit out of my price range..... like 20k more than I am wanting to spend.
Cost is the #1 reason why.
Reason #2 is that I can! and I can go at it at a snails pace. perfect!
The Khana I will make from 2"x4"x10' that will be cut into 4 pieces.
I may use 2'x6'x10' or 2x8x10''.... reasons why are actually worth noting for anyone else looking to DIY a Khana
we all know, the less knots the better. Wider boards may provide that more readily. Ill be cutting some boards down soon and let you know what I find(ill be buying home depot douglas fir)
perhaps someone already knows... Is wider better in this specific case?
The other reason is a numbers game. A 2x4 is actually 1.5x3.5'' if you cut 4 lengthwise pieces you will have 4 pieces of 1.5x(3.5/4) .875" or 7/8th" probably actually a little bit less from what the blade takes away.
now if you do the math for a "2x6" or a "2x8" or "2x10" you will find!
2x6 = 1.5x5.5 cut into 5 pieces 5.5/6 = 0.916'' aka 11/12th
2x10=1.5x9.5 cut into 10 pieces 9.5/10 = 0.95'' aka 95/100ths (I guess you could say) way more than the .875 from the "2x4"
So the point is using wider boards will yeild slightly thicker khana boards...
doesnt seem like much to us but if you using the metrix system
a 2x10 would yield you a 24.13mm thick khana board
a 2x4 yields a 22.22mm
So again not a huge difference, but it could be worth nothing if your supporting your roof with the khana
will post more later
EGEW 01-07-2017 10:35 PM
Hey Hierony!
Thank you.
I'm no architect, and hopefully someone who is sees my idea and can let me know if 2x6 for the vertical supports will be enough, and if 2x6 for the rafters will be enough. yikes so much to worry about!
Im quite certain ill need to use 2x8 for the verticals and probably for the rafters as well.
I've asked some local contractors about sourcing wood. They say home depot or lowes (ugh big box stores, i actually kinda like/hate them) is pretty much it, unless you need some other fancy woods there are some lumbar yards a little further out of town (denver) . I have'nt search for lumbar mills though... hummm........
Its going to weigh a few tons... no doubt about that.
I'm not sure how i'm going to build the base yet. probably going to involve some concrete, a very strong platform And a lot of insulation. (and maybe a crawlspace/cellar)
Certainly not going to be moving it..... probably ever!.
I may even do a more modern insulation in the walls, since Ill have the support beams there. almost makes the khana unnecessary... but hey if a bear tries breaking in im sure the khana would slow him down.... a little.
EGEW 01-07-2017 10:57 PM
This is the video that sold me on making a fourty footer
https://www.youtube.com/watch?v=VuuIgQEMOlw
its a beautiful yurt made by shelter designs yurts. it has a very impressive supporting central beam. Im not sure what size roof rafters they use. i think they are 2x8.
The goal of my design is to cut the wood as little as possible.
with 8ft wall height I wont have to cut the 2"x6"x8' that will be supporting the roof rafters.
By using such a large toono @ 11.7ft the 16ft roof rafters will work great, and may only need to be cut on one side to fit against the verticle support 2x6.
Thinking about making the toono out of metal...... I'm not sure how im going to pull that off...... but i think it could be made lighter weight then one of wood and would last longer, and be stronger than wood.
Any thoughts on making a 12 foot metal toono please give me some food for thought.
Bob Rowlands 01-08-2017 10:25 PM
A yurt is a tent, and tents do not hold up to weather long term like houses do. JFWIW. My little 16'er has been up for about three and a half years, and the canvas cover needs replaced. It is shot.
A 40' yurt is incredibly immense, in comparison to a 30'er, a huge yurt. Remember as great as they are, yurts are not houses. They most definitely are tents. IMO you would be better off starting with a much smaller yurt, say a 24'er, and then adding another as time goes by. If you do end up with an immense 40' yurt, you may have trouble selling it if it ends up not being what you are hoping for. Just my opinions here. Personally I would never consider a yurt near that big, based on my experience with my 16'er.
EGEW 01-08-2017 11:45 PM
Hey Bob!
I certain see your point. Calling this a "yurt" is a bit misleading. This structure I am build is only going to have the shape of a yurt. By no means will it be portable, heck it would take a team of 40 yaks just to move the lumber. :D:D:D
What I am building is going to be a home for my budding family :) I'm shooting for something comparable the yurt in this video https://www.youtube.com/watch?v=VuuIgQEMOlw (same one linked in my last post)
I'm surprised your canvas cover is shot after 3.5 years. Is that typical?
I've done a bit of looking around for cover options. (heck I may use a corrugated metal roof)
Duro-Last says their material will last 15 years. And you can place an order with them directly to make your cover. they will do custom made to order covers. Sweet!
A huge part of building this yurt is going to be working with a permitting office, and getting their stamp of approval. This very well may impact my plans.
Also I don't have land yet, So its kinda hard for me to say for sure what kinda snow loads & insulation needs i'll have. Who knows were this new home will be built. Could be here in colorado, could be in the pacific north west! (bigfoot country, holler)
Question! is there any older threads showing a 40ft build? I love forums but these old forums wont search short terms like "40ft" the built in search engine rejects it. Also sorry for all the typo's........ I'm half lazy and half dyslexic, horrible combination to have.
Here are some pricing calculation for the roof and walls
roof rafters 2x6x16 72pc = currently about $10.50ea => $756 => round up for good measure => $850
Support beams 2x8x8 About $6.75 each 72 needed => $486 => round up=> $550
khana 186 x 1.5x0.75x10foot => 48 x 2x4x10 @ $3 each = $144 +> round up => $200
So rafters+support beams+khana $850+$550+200= $1600
pretty good! hopefully I can get away with using 2x6 for the rafters.... 2x8 would knock this price up a bit.... how much you ask well
2x8x16 are about $14 each => $1008 => round up to =>1150 for good measure
making the new total => 1150+550+200 = $1900
Still not that bad. Gotta love circles, most square footage for a given perimeter.
EGEW 01-09-2017 12:29 AM
I was previously wondering about making the Toono out of metal. Having a 12ft metal ring custom made, would be crazy expensive.
So I began searching the web for possible sources for a 12 ft metal ring to use for a toono or something of the like, a compression ring.
Came across 10 12 14 15 ft trampoline frames. these are easily acquired for little money. The canvas like stretchy mesh wears out after a few years and then people list the frames on craigslist all the time. Usually for less than $100.
I'm thinking about using two of them, one on top of the other serperated by a few inches. maybe notching the roof rafters to accept the metal trampoline frame. or attach the rafter to the trampoline frames with half round metal clamps, like conduit hold down.
Cad drawing coming for this trampoline ring/frame idea.
hierony 01-09-2017 01:27 AM
Building codes may be against you, especially in terms of insulation. I don't know the R-values off the top of my head, but at least 3.5" (2x4 depth) would likely be required.
One thing to keep in mind is lumber grades--stud standard or No 2 is pretty marginal (lots of knots & other imperfections), but the rated stuff can be darn nice (for what is available nowadays). I've only seen the rated stuff at the truss manufacturing plant where I worked during college, but the big box stores *might* have it. As a retired carpenter, Bob likely knows more about this though.
I would be very dubious about using trampoline frames for a crown ring--snow & wind loads get partially transferred to it, and with such a large yurt that would be a rather substantial force. The major problem detail would be the connections between crown ring pieces (strong welds?) and the amount/cross-sectional area of the material there (also roof pole-to-crown-ring). A geodesic dome of sorts may work, but that is something I'd suggest consulting an engineer about. The crown ring is the heart of the yurt--you really don't want it to fail.
Yes, plain cotton canvas degrades pretty quickly in sunlight; Colorado has pretty high UV exposure & I suspect Bob used lighter canvas than most yurts. But 3-5 years isn't bad for constant exposure of a natural fiber. The modern treated materials last a bit longer (15-30 years) according to the spec sheets, almost comparable to asphalt shingle roofs.
Jafo 01-09-2017 07:28 AM
I know Nomad Shelter yurts makes a 40 footer. You might want to check out their design. I am happy to see you will have center supports of some kind because I think that is wise with a larger yurt.
I would think 2X4 vertical supports would be just fine, but I would definitely go with the 2X6 on the rafters. I almost wonder how much cost difference there would be with LDL's? Probably a lot.
