The Yurt Platform
Old 10-06-2013, 02:50 PM   #11
Default Re: The Platform
Originally Posted by Robo View Post
You know, I'd really like to do that, but I don't have the computer chops to load pics on here, or anywhere else for that matter. I'm 'computer challenged' lol I'd have to have someone who knows how to load them looking over my shoulder and showing me step by step how it's done. Bummer. :/
Here is a how to on how to post pics here.
http://www.yurtforum.com/forums/yurt...ow-to-407.html
Old 10-06-2013, 09:08 PM   #12
Re-erected my yurt atop the new platform today. Penciled the yurt outside diameter line onto the deck. Khana anchored to line on deck with hand made 90 degree angles that bolt through the lowest lattice cross and into the platform with screws. Solid and perfectly round. I'll have my son help move the woodstove back up into the yurt, since my back is killin me.
Now gotta build a couple double sleeping bunks and big table for the grandkids to 'camp out'. And papa and grandma too.
Old 10-06-2013, 09:12 PM   #13
Thanks Jafo.
Bob
Old 01-07-2014, 07:32 PM   #14
hey y'all. My friend is a carpenter and helped me design a 20 ft. deck/ saved me a good bit of money by reducing the number of cross beams/ concrete piers needed. two osb bands around the edge/ advantech as the only floor (floor paint does wonders)/ eventually foam board
will be installed underneath. The square boxes you see in the corner are insulated to hold food and can be accessed through "secret compartments" in the floor
Initially I went to my friend with the free plans from pacific yurts/ while they are good plans this seemed to drastically shave off the materials cost and is extremely solid.
ID:	484   Click image for larger version
ID:	485   Click image for larger version
ID:	486   Click image for larger version
ID:	487   Click image for larger version
Old 01-07-2014, 07:34 PM   #15
two more...
ID:	489   Click image for larger version
Old 01-07-2014, 07:41 PM   #16
Looks good and solid!
Old 01-07-2014, 08:29 PM   #17
Very nicely done. Good job.
Old 01-28-2014, 05:44 PM   #18
Beautiful platform!
I am deciding between conventional platform like yours or a Structural Integrated Panel floor (4" thick insulated plywood "boxes" with R16 rating) assembled directly on top of a post and beam style base. Any comments from you would be very helpful. {The SIP panels will cost about $6000}. I live in moderate climate with occasional snow rarely up to 12" deep. I need to commit to materials soon. Thank You,' Doug 530 575 1842
Doug is offline   Reply With Quote
Old 01-29-2014, 12:27 PM   #19
IMO $6000 is alot of money for a yurt floor. With that $ amount in mind, I'd stay with conventional framing on top of the post and beam. Convenional floor framing is used everywhere because it is relatively inexpensive. Fast and easy to frame. Every journeyman carpenter knows how to frame a floor. As for
, I'd install conventional fiberglass batts for the same reasons. But this is JMO.
