09-11-2020, 10:12 AM
#4
Re: Rain cover with ventilation for tono in Mongolian Ger?
All the above assumes you have a stove pipe through the hole in the roof, holding the cap in place. This was my set up for winter use here in CO. I tie wired my single wall pipe so it stayed centered in the ring, regardless of how hard the wind blew. I installed screw eyes in the bottom of the ring and attached the wire to those. Absolutely bomb proof.
If you have no stove pipe, you can still tie wire the china cap in place using several screw eyes set in the ring. Leave enough slack in the wire that you can lay a 2x atop the ring to prop it up for ventilation. If you really need to hold in the heat or keep out all rain, remove the 2x and stash atop the wire, tight up under the ring. That should take out the slack so the cap doesn't hop up and down in the wind.
If the hole is smaller than a metal trash can lid, you can make a cap out of that. You might be able to hang a large umbrella up there. Think outside the box.
