10-03-2020, 11:23 PM
#6
Re: How do you attach Tyvek/R-13 fiberglass to a Ger?
A single layer of canvas will not begin to keep in the heat after the wood stove fades at night. Been there done that.
As for insulation, I would not bother trying to invent some system to install r-13 batts on any lattice wall yurt. Nor would I mess around trying to water proof uncoated canvas that has no factory applied water repellent.
If I were building another yurt as a home, I would use felt between the inner cover and outer cover, just like the Mongolians do. I assure you that if you come up with a system that traps moist air in the wall/roof, mold will ensue. That exact issue has been brought up on this forum a few times in the last several years.
Personal experience, I used treated canvas on all three of my yurts, no insulation. They did not hold heat at all. Fire out, yurt cold-pronto. Plus, the 100% canvas cover was leaking rainwater/snow melt within four years of full time weather exposure. Also mold set in during the second year, albeit just a mild case- no smell. It increased yearly until the cover was totally worthless.
IMO the best way to go for anyone considering long term yurt living, is to get a professional 15 year cover. And spend the money and felt it.
Hopefully a pro will address this issue. Good luck.
