06-19-2015, 07:45 PM
#5
Re: Help! Trouble shifting roof on a 27' yurt
If you piched your yurt with the roof too low, and you have the bulk of the rafters in place, it is gonna be a miserable mother trying to raise the ring height. I suggest you contact the yurt maker for the proper ring height, and make a stand to set it at the correct height BEFORE any rafters are installed. Also ask the yurt maker for the suggested length. Once that is known set the cable to length, install it at the top of the wall, and THEN start setting the rafters.
Hope this helps. Good luck
